STR DN1060 BiWire
JesperAa
New
STR DN1060 BiWire
Hi It is possible to BiWire my DALI 850 speakers as front speakers in a 5.1 setup, using the front and back connections for the DALIs. My configuration will then be front - center - back, but the back-speakers will be connected to the surround-connectors - how will this work? Is it a problem that the DALIs are 4 ohm or does the 1060 have enough power to feed them?
1 REPLY 1
kulbhupa
Explorer
Did you manage to get the BiWiring to work with you speakers in the end? I had a pair ot old Tannoy 609s which were bi wireable, so biwired them from the STR-DN1060 and I have a 5.1 set-up. I have to say I did not really notice muh difference in sound quality.
