The internet won't open.
profile.country.en_GB.title
Imogenn
Visitor
I've just purchased a new sony laptop, but the internet won't even open. Why is it doing this? It's being very slow and the screen sometimes turns off.
2 REPLIES 2
Blencogo
Hi Imogenn and welcome.
You don't give us much information.
What do you mean by the internet won't even open?  What error messages do you get?  Has the internet never worked?  What software have you installed?  You don't tell us what you have tried.
If it was working when you first used it, perhaps you should return the software to factory settings as the problem is probably something you have installed.
If the Vaio was faulty from the start, you should take it back to the shop where you bought it and ask for them to fix it for you or change it for another one.
:thinking:
firionicable
Visitor
Since you have just bought it and already getting a lot of problems, it would be better to have it replaced where you actually bought it.
