Vaio T1XP Hard DRive Replacement
profile.country.en_GB.title
Storm924
Visitor
Hi,
My trusty T1-XP is finally giving up the ghost! It has a problem where it powers up but does not boot up, i have found a work around where i turn the laptop over and give it a gentle tap on the underside and then try switching it back on, 7 out of 10 times this works and the system boots up and the laptop works perfectly.
I'm not sure what's going on with it, possible a loose connection or perhaps the hard drive is on it's way out.
Does anyone have any ideas what could be wrong or experienced similar issues.
Thanks in advance!
1 REPLY 1
Blencogo
Hi Storm924.
I think you have guessed that it must be a poor contact somewhere which may need a look inside.
It may be worth checking that the Memory Modules are seated correctly by removing and reinserting the RAM.  Have a look at Page 103 of your User Guide: -
ftp://ftp.vaio-link.com/pub/manuals/Notebooks/B_S2_T/B_S2_T_H_EN.pdf
:thinking:
