Since the latest update, I've had an alarm notification pop up on the notification bar that I can't get rid of. Has anyone else encountered this?
Solved! Go to Solution.
Not that it should be a factor, but i ordered my xperia 1 from the UK.
Any in common perhaps? What can we exclude? Which are suspect?
Accu Weather
Arlo
AVG
Bose
Chase
City Mapper
Fire TV
Fly Delta
Hilton
IHG
Kasa
Lifelog
Lightify
Meet
Netatmo
One Note
Skype
Smart DNS Proxy
Smart Cam
Smart Things
Spotify
Trip Advisor
Wear OS
What's App
That needs to include any and all system apps if your phone is branded, or has operator firmware/apps as well.
If the problem were a system app, would it not affect all phones?
Finding it difficult to understand why this problem is only happening on a limited number of phones?
If for example a Microsoft or Apple update causes issues, it is normally in the newspapers the following day.
Not saying at all that you are not right, just owning up to my stupidity.
I am right, and it may be a user installed app, Tasker for one, I know does that, there's a setting in Monitor - Reliable Alarms, you need to disable, or it puts out the never ending alarm notification to stop being killed by the Android system.
It may be an app installed from a carrier, or on branded software/bloatware.
Then as you say, it would affect only some, and not all.!
Now go into your app tray, open files, and open the phone, and check if you have a "Download" folder.
Sony News Suite has a habit of dumping files of some size in there from time to time.
If you do find them, just delete them.
Uninstalling news suite solved it for me too.
