If the Android version didn't change after the update, then it will be mostly a bug fixing update or may be introducing minor tweaks. Sadly you won't find a definite changelog on this forum.
Hi @Ah4
I suggest check this link:
/t5/Software-Updates/Lollipop-New-Features/m-p/955490#U955490
Don't forget to mark posts that answers the topic as Accepted Solution.
If you find any post helpful, press Kudos.
I'm at disposal for any question.
Best Regards,
i didnot receive new version from andriod 5.1.1
is it available for my phone ???
Hi @Ah4
I suggest you check this links:
http://blogs.sonymobile.com/category/software-upgrades-2/
http://talk.sonymobile.com/t5/FAQ/The-software-update-collection-topic/m-p/348066#U348066
Best Regards,
u didnot give me any answer
thanx for your effort
pls i want the Mobile ID for Sony
