Hi, My m4 after update to andro 6 shows only 883 MB Ram... it has 2 GB Ram memory, why is not the whole memory working? Its not all, my front camera is not working and the system is working really slow... I allready have repaired my smartphone via Xperia Center but the issue still occures. Don't write to me that I should go to the local servis, because that is the last thing that I will do. There must be any solution...
Solved! Go to Solution.
My issues with this mobile started just with the signal problem, have been looking for a solution ever since and the phone only gets worst. If my warranty is still on time i will demand for an equipment change, if not i am going to try and flash i with a custom rom since sony seems uncapable of fixing this issue, not going to buy a sony cellphone ever again....
@Vinitpatel and Closertitan45
The only fix appears to be hardware replacement which is what Sony did for my phone (it was still under warranty).
I hope you find a solution to your issue.
Best regards,
BH06
I have the same problem : M4 aqua dual very slow, blue screens, 883 MB RAM available, no front camera. No solution at the moment? I will order a new phone and it will NOT be a Sony...
