4.0.4 update list is inconsistent
SOLVED
xenkof
Visitor
Hi,
I have 2 SE Arc S's, both bought locally in Cyprus from my provider FULLY UNLOCKED.
The first one (black) was bought in November 2011 has an SI of: 1254-1140
The other one (white) was bought recently and has an SI of:  1254-0680
The white one is listed in the 4.0.4 thread as being eligible for the update since the 15th of August and indeed I updated it through PC Suite just fine.
he black one is listed on the sam thread as eligible since the 3rd of May, but it's stuck on 4.0.3. I have tried through SEUS, through PC Suite and OTA and all of them say it's up to date.
Did someone just merge the 4.0.3 update list with the 4.0.4 one?
PS. The 3rd of May date is around the time 4.0.3 was released and I upgraded to that, so it can't be right that 4.0.4 was released on that date as well.
1 ACCEPTED SOLUTION
Accepted Solutions
Johan
Master
In the SI list you can now see which build number that's latest for each and every SI number. The updates roll out gradually.
3 REPLIES 3
Uliwooly
they are not quite unlocked, for the most part, if a network sell a phone "unlocked" they call it unlocked when they should call it contract free, as the updates is still dependent on them to approve and release it.
xenkof
Visitor
Yes, that could be, but that does not change the fact that they were both bought from the same provider and that there is a problem with the list.
Johan
Master
