Help..Help..Help... Sony Xperia S Charging Problem
SOLVED
Cyrusdude
Visitor
Hi...
      I have a Problem with my Xperia S..When i Charging the mobile..My Mobile NETWORK is DISCONENCTED.
and when i am SWITCH OFF the MOBILE.. It's show BATTERY METER & ORANGE LIGHT(NEAR SENSORS) CONTINUOUSLY ON.
PLEASE HELP ME...
My Email ID:- [email protected]
1 ACCEPTED SOLUTION
Accepted Solutions
Johan
Master
Check if this can be cured by doing a software reinstall using SUS.
http://www.sonymobile.com/gb/tools/update-service/
If not I suggest that you contact your local support team to have your phone fixed at an repair center.
http://www.sonymobile.com/global-en/support/contact-us/contact-info/
2 REPLIES 2
Johan
Master
Cyrusdude
Visitor
Thanks for your reply.
But i am ALREADY Updated my Xperia S with ICS. It's STILL Showing..
Thanks..
