not getting update notification
SOLVED
sohamp6
Visitor
not geting the update notification for jb
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
you are not going to find that answer here or anywhere else, you have 2 options
1) wait
or
2) manually update your phone
if your phone is or was locked to a carrier/network branded, contact them as it is up to them to approve and release the update.
8 REPLIES 8
chris20131
Visitor
I have the same problem too.
profile.country.RO.title
_alexdon_
Check both PCC and SUS.Are your phones locked in a specific network?
alexdon
chris20131
Visitor
I check with PCC and SUS. No,the phone is not locked.
I dont know if the update process has finished...
Sony can hear us???
Uliwooly
you have to wait for the update to  be approved and released in your country.
chris20131
Visitor
Until when? End of July? August? Sepetember?
Uliwooly
1) wait
or
_alexdon_
Sony usually does not hear.Anyway,you can follow uliwooly's advice.
alexdon
Uliwooly
How to manually update, downgrade, root 2012 Xperias
http://talk.sonymobile.com/thread/41609
