you are not going to find that answer here or anywhere else, you have 2 options
1) wait
or
2) manually update your phone
if your phone is or was locked to a carrier/network branded, contact them as it is up to them to approve and release the update.
I have the same problem too.
Check both PCC and SUS.Are your phones locked in a specific network?
I check with PCC and SUS. No,the phone is not locked.
I dont know if the update process has finished...
Sony can hear us???
you have to wait for the update to be approved and released in your country.
Until when? End of July? August? Sepetember?
Sony usually does not hear.Anyway,you can follow uliwooly's advice.
How to manually update, downgrade, root 2012 Xperias
