Sim card and contacts
SOLVED
Not applicable
Hi, I have xperia x10 and have just updated to 2.1 - after back up and restore the phone cannot read the sim and I have lost all my contacts.  Any suggestions on how to regain my contacts.  Pls help!
1 ACCEPTED SOLUTION
Accepted Solutions
gwhispererz
Champion
Ok, great! From HOME screen, MENU (left hard key, the one with 4 small squares)>Settings>Accounts & sync, tap your gmail account. This will sync your gmail contacts to your phone. Make sure you are connected to Wi-Fi or Network data (3G). Slightly_smiling_Face
9 REPLIES 9
gwhispererz
Champion
Hi Jtuff, any other places that you have saved your contacts? SD Card or sync-ed to your gmail account?
Not applicable
Not that I know of.  I have been left with about 5 contact names and numbers.
gwhispererz
Champion
I need more info to understand your situation. What you are saying is phone is unable to read SIM Card for your contacts? Did you try manually importing contacts from your SIM Card?
Not applicable
Sorry this phone is relatively new and driving me crazy.  I have just gone onto my pc and logged on gmail account.  All of my contacts are there.  Sorry if this sounds silly but how do I get them from gmail back to my phone?
gwhispererz
Champion
Not applicable
Thank you, thank you.
gwhispererz
Champion
Glad that you have sorted out. Slightly_smiling_Face
Enjoy your phone.
Not applicable
I have a similar problem. My phone has never been able to "read sim". However after the backup many of my contacts that are on googlemail dissapeared. I have it set to read googlemail contacts but they dont appear. If I go Phonebook > cannot read sim > edit contacts, I can see them. But why do they not appear in my contact list and better still how do I get them there? Any help would be much appreciated.
Uliwooly
Phonebook -> tap on the three-headed monster -> tap on Google -> check all the groups
