Sony Xperia t not charging
Sibles24
Recently updated phone, battery run completely down overnight now won't charge, connect to PC or anything, any help gratefully received. Thanks
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
Thommo
Genius
Looks like the battery is knackered
So you can either contact Sony to find your nearest service centre http://www.sonymobile.com/global-en/support/contact-us/
or buy a replacement battery from eBay for example and then use this guide to replace it yourself
24 ODPOW. 24
Thommo
Genius
Have you let it charge for several hours before re attempting to turn it back on
It may also be that as a result of a total discharge you have damaged the battery so if the charging as per my beginning doesn't work then contact Sony for further help in regards to locating a Service centre http://www.sonymobile.com/global-en/support/contact-us/
Sibles24
The charger light does not come on when plugged in to charge, have left the phone at home plugged in and hopefullly it will change and will look at it again at lunchtime.
thanks for your help - will keep you updated.
Sibles24
I've left it plugged in for 4 hours, still nothing no light when charging, phone is as flat as a pancake, am imagining the battery knackered, any advice on that please, I have photos, contacts, diary etc on there that needs to be removed.
Thanks Sam
profile.country.RO.title
_alexdon_
Try to download sony update service,see if it is able to find your phone and repair:
http://www.sonymobile.com/gb/tools/update-service/
alexdon
Thommo
Genius
Sibles24
Thanks, I've purchased a battery and my oh is going to fit it so hopefully this will do the trick, am just concerned after reading some of the other comments on the forum that this was caused by the update 😕
riverjeans10
Me too. battery run completely down overnight. Now I have it connected to the power cable.  It turn on, last 5 secs, turn off again and keep turning on and off  in a never ending loop. How fixed it?
_alexdon_
You could also try to look for a battery.
alexdon
anjakej
Did u managed to fix it?I have the same problem right now
