Xperia Mini Pro (SK17i) start error.
SOLVED
fullZNDH
Visitor
Hi there friends. My Xperia Mini Pro (SK17i) can't start properly. When I turn it on, the Sony logo appears but then shows a exclamation mark inside a triangle and then he shutdown again.
Can someone try to help me? I'm getting desesperate. Slightly_frowning_Face
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
you have 3 options
1) repair your phone with SUS
2) take your phone to a Sony repair center
3) repair your phone with flashtool
8 REPLIES 8
Uliwooly
you have 3 options
Uliwooly
fullZNDH
Visitor
So it means that my phone isn't totally damaged? Im going to try the first method that you described up there. Can you help me to do that? I don't want to make any mistake Neutral_Face
Thanks in advance! You giving me some hope.
Uliwooly
you should be able to repair your phone
my suggestion is try
1) SUS
2) flashtool
3) sony service center
fullZNDH
Visitor
It worked! You're the man! THANKS!!
I think im not trying to root it again now... I prefer low memory instead of get my phone with problems again.
Uliwooly
as long as you don't unlock the bootloader you can repair your phone with SUS
fullZNDH
Visitor
So, do you know any secure methods do root 4.0.4 in SK17i without unlock the bootloader? Winking_Face
Uliwooly
How to manually update, downgrade, root 2011 Xperias
http://talk.sonymobile.com/thread/38251
