Hi every one, My XS battery is draining too fast i dnt know why is that here i have been attached som images please help me
-91dBm 11 asu and mobile network type EDGE:2
I still think the problem is those apps and the poor network coverage, do you get 3G from your carrier? if you don't then
settings > more > mobile networks > network mode > change it to GSM only
yes i am getting 3G from my carrier. But, now i uninstalled the virus guard which i had and i am not having any battery apps or task killers. My battery has been dropped upto 9% already. i am going to chek my battry status again tomorro morning from 100% - 10%. after that i will let you know will you help me again :smileysad:?
yeah I'll be here
thank you thank you very much
for your patient.
thank you for your help dude i cheked my battery life by uninstalling virusguard its just awesome my battery life is back
