I have a wall mounted NX810 LED tv .
Wish to replace the speakers on the stand connected with HDMI.
Any solution appreciated.
Not wish to connect to my stereo system.though.
Hi,
the only thing you can do if you do not want aux speakers is to use the built in ones of the tv once you remove the speaker stand, you can select them in the sound menu by clicking on tv speakers.
Sure....but they sound even worse
İsn't it possible to hook other speakers to the existing HDMI connection ?
Does not to be Sony ..
Maybe wireless ?
Hi again,
only way via HDMI is with ARC through a dedicated home cinema system if you want decent sound.
Thanks.
