Alternative speakers to replace those built in on the stand ?
profile.country.tr_TR.title
demird
Visitor
I have a wall mounted NX810 LED tv .
Wish to replace the speakers on the stand connected with HDMI.
Any solution appreciated.
Not wish to connect to my stereo system.though.
4 REPLIES 4
profile.country.en_GB.title
Bravia55HX
Member
Hi,
the only thing you can do if you do not want aux speakers is to use the built in ones of the tv once you remove the speaker stand, you can select them in the sound menu by clicking on tv speakers.
demird
Visitor
Sure....but they sound even worse :upside_down:
İsn't it possible to hook other speakers to the existing HDMI connection ?
Does not to be Sony ..
Maybe wireless ?
Bravia55HX
Member
Hi again,
only way via HDMI is with ARC through a dedicated home cinema system if you want decent sound.
demird
Visitor
Thanks.
