At every channel change darkened horizontal bar on top NX 810
profile.country.tr_TR.title
demird
Visitor
Is there a setting to eliminate the dark bar showing at channel change for seconds  ?
1 REPLY 1
profile.country.en_GB.title
Bravia55HX
Member
Hi,
if you are referring to the current channel information bar shown after each channel change then no you cant.
