kdl-50w685a Faulty - Yellow Vertical Lines
Well this is more of a rant than asking for support because the TV is truly screwed.
Yellow vertical lines running down the screen with a high pitch noise. Seems to be a common fault with Sony Bravia TV.
TV is barely 3 years old, and it's already developed a fault. I would had thought paying near towards a grand you would certainly get longer out of it. Sony has really dropped in quality over the years.
1 REPLY 1
Anonymous
Not applicable
Hiya
You're welcome to have a rant.  I surely do at times - it works too :slight_smile:
I dont think this is a comom fault with Sony TVs - But verticle lines can be a fault across the LCD technology.  Could be a loose connection between panel and PCB.  Faulty T-Con board or LDVS cable - or even panel failure.
You could have an authorised Sony repair center diagnose the fault and quote you on a fix (assuming parts are available).  If indeed its the panel, it would certainly be un-economical to repair.  See:
http://services.sony.co.uk/support/en/repair/asc
Cheers
