windows 7 and drivers problem
profile.country.en_GB.title
Romeolo888
Visitor
hello all
right, this is the situation,
i had windows 7 Chinese version installed on my vgn-z11vn laptop.  Everything was working fine including all the drivers.  After a while i couldn't stand the chinese characters at the end of the day so i wanted to sofwindows 7 english version.
Ok so i reinstall the english version of windows 7 on my laptop, but it seems to have saved all the drivers from the previous chinese install.  This is where the problem starts
in device manager i have three contents with 3 exclammation marks that will not work on my computer as below:
Base system Device
Unknown device
SDA Standard Compliant SD Host COntroller
ok
so i already got all the drivers downloaded and when i try to install the SDA Standard Compliant SD Host COntroller, it says i cannot install this because it is already installed.
so here, i gathered that the previous drivers were installed so i install all the utilitys and original function drivers to see if there would be any change.  and i am still stuck with the above contents that i cant install.
Please can someone help, this has been doing my head in all day.
thanks for your time all
2 REPLIES 2
Blencogo
It seems to me that some or all of these relate to the MemoryStick/SD Card Slot drivers.
Have you reinstalled BOTH the Ricoh MS and Ricoh SD Memory Card Read/Write Drivers from here: -
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VGN-Z11VN_B
:thinking:
Romeolo888
Visitor
right, after figuring out what was wrong with the probelm it was sytem base device that was a problem
a simple problem that was caused due to failure to unzip the file from the zip, lol
thanks for help all!!
I have no problems in device manager now.
