How to replace the speech input button with the dot button?
Not applicable
I am using the Xperia Chinese Input method , and when I switch to the English keyboard, the speech input button is at the dot's place, which lead to great inconvenient to me. When I am inputing a website address, I must click the number button and click the dot and switch to English keyboard to continue. I don't use the speech input, so is there a way to replace the speech input button with the dot button? I have already disabled the speech input in the setting, but it is still there.
It annoyed me so much.
Thank you!
10 REPLIES 10
Uliwooly
you will have to use a different keyboard
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
http://talk.sonymobile.com/thread/44888
Not applicable
I faced the same problem. what I did was disable Voice input, disable Voice dailer. Then configure keyboard. Now I have the "dot" on my Chinese keyboard.
skip0pot2mus
Visitor
So how would you get the mic button AND the full stop button on the keyboard?
profile.country.en_GB.title
almightybong
Visitor
There actually is a more correct way of doing that. Follow the steps below:
1. Go to Settings > Language & Input
2. Under Keyboard & Input Methods, tap on the Settings button for Xperia keyboard
3. Tap on Keyboard appearance
4. Tap on Additional keys
5. Tick the checkbox for Full stop and comma keys
That should do the trick.
Cheers, mate!
almightybong
Visitor
You can refer to my previous post and do steps 1 & 2.  And then tick the checkbox for Google voice typing key.  This should give you this keyboard layout:
Not applicable
Sorry, can you describe it in detail?
您好,您能说详细点吗?为这个东西烦透了,在输入法设定里面一遍遍找也不知道怎样去掉。
Uliwooly
Hello, you can speak in detail some? Fed up with this thing, found in the IME mode set in again and again does not know how to get rid of.
Not applicable
Thank you for your help. But maybe we are not using the same input method, the opinion in the different keyboard setting is not the same.
I still can't manage it.  ┑( ̄。 ̄)┍
spife
Visitor
I think there's a bug in sony's input methods. When you untick google voice input, it should automatically remove the voice input icon from chinese input method. However, this is not happening. After I rooted my phone and installed google now for ics, (essentially a new version of google search), I can disable voice input icon from the chinese input by disable/untick google voice input from the menu.
