Sony please tell me whether xperia xz has a metal frame or is it some kind of plastic? Thanks.
Xperia X Performance not have metal frame, frame is made of polycarbonate.
Solved! Go to Solution.
Good job remembering all that
Sadly, the thing about fingerprints doesn't actually seem to work.
I've had mine for 2 hours and its got finger prints all over the back - even though my hands are generally dry to the touch and not sweaty.
Not too bad though.
The important part is, that Aluminum is a good heat conductor - unlike previously used glass and plastic backs, which certainly didn't help with the overheating problems on various Z phones.
These phones shouldn't overheat with that big aluminum slab in the back. Though my camera causes "heat rising, functions are being disabled" messages to pop up within 2 minutes
Probably less resistant that Z5 frame. Reported result of a XZ drop:
http://forum.xda-developers.com/xperia-xz/help/sexy-durable-t3485665
