Xperia XZ headphone jack malfunction
sc1207
Visitor
Hi all,
I've been using my Xperia XZ for about 2 months now and I've been having very annoying problems with the headphone jack.
I tend to listen to music with my phone in my pocket but the slightest pressure on the headphone plug seems to make the phone detect the headphones to be removed. I have tried a straight plug, an L shaped plug and different sets of headphones and the results are all the same. My music never continue for more than a few steps if I walk around with my phone in my pocket.
Secondly, I use headphones that do not have an in-line mic and controls but the phone keeps thinking that I have pressed controls on an in-line mic and activates voice search functions which is also highly annoying.
Just wanted to see if these are common problems with the XZ? If not I might bring it in for servicing
31 REPLIES 31
Yohdh
Visitor
The funny part is: it was working with a regular headphones, but since i have plugged a new one with mic, now only works with these ones...
Yohdh
Visitor
Ok, I thought a xperia restore could solve the issue, due to a misconfiguration or something... and it really worked out.
I restore the phone and now with both headphones (with/without mic) everything is ok.
Bigjamer
Visitor
Having the same problem with both so you wireless headphones and my Sony sports over ear plugs, the music event starts and then stops again. I have found a couple of work arounds by pulling the jack in and out but this will ultimately ruin the socket. I tried Sony support, what a waste of time, they told me to perform a factory reset which did nothing at all except annoy me greatly by having to reset all settings again.
tzfsr
Visitor
I have the same exact problem and it's the worst thing ever, I hate it so much, but I can't even use headphones anymore, some people said to use a headphone app called wizdroid... that didn't work, so I used an app called smart key, by Sony. Thank you, it works fine until i got Bose earbuds and now I can't listen to anything on these new earbuds, please do something or else I'm going to get a new phone, I'm really sorry but this is not ok.
Dotte
Visitor
I've had the same problem since yesterday.
I've been using Sony headphones since I've bought the xz, and suddenly the phone won't accept the headphones. They've been working perfect otherwise.
DaniMartii
Visitor
I had the same problem. At the end I could fix it by cleaning the port with compressed air. You can buy a can from Amazon. They're usually used to clean computer parts, so I don't think you can damage the device but I'm no expert.
kdomingo
Visitor
currently experiencing the same issue! disconnect after 5secs. how long has this been an issue from xz users? beats earplugs work on my dell laptop but not in my xz
Dankzephyr
Visitor
Thank you!!!!
HavingTroubles
Visitor
I have been using a pair of Sony Ex 650-AP earphones,for my sony xz, which I have been using for 2 months, (great earphones with inline mic), last saturday they just stopped working , at that stage I had NOT done the december upgrade for my phone. I tried removing headphones and reinserting but still didnt work, I also tried rebooting phone but that didnt help either.However when I plugged the sonys into my home computer they worked fine I later tried a pair of Sennheisers CX-300s in my phone,that only have one bud functional which worked fine .I have since done the December upgrade for android 8 but the Sony 650s still dont work in my phone.
Tags (4)
seandrogan
Visitor
I figured it out, I too faced this problem after updating my phone, I never realised so much different type of heaphone jack,TS, TRS AND TRRS the one the work is TRRS for xz now for some reason. So yeah you need a new cable. TRRS HEAPHONE JACK. Cheap on ebay.
