Need help with lockscreen
SOLVED
GrumpyPete
Visitor
Hi,
  I installed the McAfee security to try it out, and changed my lock screen to swipe only. I turned the phone off and on again this afternoon, entered the McAfee pin, and now the lock screen is asking for a pin. I've removed the McAfee, and now all I get is the digit lockscreen. I've tried my old pin, the McAfee pin, all the default pins I can think of. I'm at a loss. I can't even get the hard reset to work. Can someone talk me through the exact sequence? Will that clear the lock screen?
Thanks,
Pete
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
that's odd, are you sure it is a pin not a password, there ins't much anyone can assist you with, you have 2 options try to remember all the pins that you've set up or use SUS to reset your phone, btw you do not need mcafee/antivirus, it creates a LOT of issues and there aren't any virus on android
Don't forget to mark the Correct Answers & Helpful Answers
4 REPLIES 4
Uliwooly
Uliwooly
GrumpyPete
Visitor
Thanks uli. I've used SUS and am back in action. :smileygrin:
Uliwooly
anytime
