Solved! Go to Solution.
I got the same problem, I took 2 pics comparing the switch on and off this Soft skin effect mode, they look exactly the same!! soft n weird skin!!
Don't know what to do ???
I went to Sony store to test on other z3 and it came out the same way with mine -Soft skin effect didn't turn off. Salesperson there with Z1 got the same thing.
Should we call it a Bug??, since it give you a choice to switch on or off this soft skin efftect ,but evidently all pics are processed to a way way too much soft skin!!
Have the same problem.
I'm a professional photographer and this effect makes my phone useless for any people photography.
Extremely bad idea by Sony.
Sony, you must fix this soft skin issue. This effects completely ruins all my pictures of people.
Appears on both front and back camera.
I'm a professional photographer and Xperia has delivered so good picture qualtiy until this soft effect came with the Z3 (compact). You need to make and update where you can remove the soft skin effect, or I have to return my phone.
I want real pictures, not fake smooth baby skin on every face.
Hey guys,
yesterday i bought the new Xperia z3 compact. I am very satisfied with the function and hardware but there is a big issue for me.
I´ve noticed that the front facing camera is very very blury. On display ist the quality very fine, but when i take a picture with the front camera , the quality will affected by the sony algortihm after the shot.
Can i improve the front facing camera by an app or upadate ? Please help me, it is very importent for me , anotherwise I would change to my old smartphone.
