Hi there
Bought an Xperia Z about a month ago. Had slight lag issues but nothing too serious.
My phone ran down and the battery died two days ago. I put it on the charge (its been on the charge pretty much ever since) with the red LED lit up. LED turns off completely when unplugged.
Phone will not turn on at all; have tried all of the manual resets (holding power button and volume button etc); have read these forums and searched the web for a solution to no avail. PC doesn't recognise the phone so can't reset it via PC Companion. Basically, I have an $800 unresponsive brick.
Very very disappointed to say the least. Phone was very well looked after, and to have it die simply because the battery ran down is extremely worrying. I've seen that this issue is very common yet there doesn't seem to be any definitive fix for it whatsoever.
Any help that anyone can give me would be really appreciated
Thank you for this.... On my Z3 Compact it worked with the power button and the volume UP button. About 3-5 seconds were enough.
Thanks Elliander,
Your method worked. I was fustrated because nothing was working with my Xperia Z3+ Dual. I tried switching cables, chargers, powerbanks etc. inshort I disturbed my entire office staff for all possible accessories.
Pressed the volume button. The device vibrated 3 tiimes and showed 100%.
Its working fine now.
Thanks for sharing.
Rahul
I seem to be having the same problem. Suddenly it stopped charging, so i pressed hard reset red button and now at least i get a RED LED. Its been charging for days. Still nothing i cannot boot, get a picture or get to recovery.
So i let it decharge for couple of weeks then tried the above. No luck.
After googling around i found out that sometimes its the battery, so i took the phone to bits, removed battery and reconnected it. Still dead.
This is one expensive dead phone.
I am now flipping up if its worth a gamble for a new battery or not
IF I CHARE MY SONY Z1 PHONE ,THE ONLY RED LED IS ONN,THATS ALL NOTHING HAPPENING,PLEASE HELP..............
The link was extremely helpful thank you!! My phone is working now.
This did not work. I bought a new HTC phone. I have had enough of Xperia and Sony! The tech had a problem with trying to revive the phone too. I want to retrieve my old photos and a USB cable is not working and I cannot power it on the tether the blue tooth. HELP!
phone was left charging over night - checked phone at 4am and was fine. woke up and phone was completely dead. no red light when plugged into a charger, not recognised by a pc. tried the power & volume button reset but no response at all. could anyone suggest anything please?
