What would you like to know about Xperia Z1 Compact?
Johan
Master
Is there something you would like to know about the Xperia Z1 Compact?
Make a post if there is something that you would like for us to test.
And we will try to check this for you. :smileysmileythumbsup:
250 REPLIES 250
roever
Visitor
Hi there.
I searched the internet and this forum, but I couldn´t find an answer to my question. Maybe it is too obvious, but better safe than sorry.
Is the Z1comp. compatible with microSDHC cards? I read that these cards will nit fit in into a normal microSD card slot, so therefore my question.
Thanks a lot for your help.
Regards,
roever
profile.country.RO.title
_alexdon_
SDHC means high capacity only,no difference in size.SDHC is a 4-32GB micro SD card.
alexdon
samsul74
Visitor
What are the thumbnail boxes in the picture app on Z1 compact? Howe can we delete them? Why do the thumbnail boxes continue to create themselves even after I have delete every picture inside of it? Is the continuing creation of thumbnail boxes actually a bug?
Best Regards..
_alexdon_
It is normal to have thumbnails,without them you would have no preview for pictures.
alexdon
Arnkh
Visitor
Will I be able to use Garmin Premium Heart Rate monitor with z1 compact? I tried connecting my Suunto Dual Comfort belt, and it didn't work. Would like to know about Garmin before I buy it.
Thanks in advance!
hgoebl
Visitor
AFAIK you need an ANT+ belt, the Suunto only supports ANT (not ANT+) and therefore doesn't work.
The Garmin should be ok for the Z1 Compact. Have a look at http://www.thisisant.com/directory/
Darkprinc3
Visitor
Plss answer me Bcoz of it doesn't have slow motion video recording in the next update I will buy z2
_alexdon_
You can edit the videos after you record.I do not think the compact will have this.Contact xperia care:
http://www.sonymobile.com/global-en/support/contact-us/
alexdon
Smellymissa
Visitor
I'm having problems with my Xperia Z1 compact camera. I have only had the phone for about 3 weeks now so still getting used to it. I seem to have options missing from my camera settings menu!
I can't choose a scene selection and don't have the HDR option either.
I have updated the phone, turned it off and on again, basically everything you've said to do in the troubleshooting section of the website but the options still don't show!!
Please help!
kdotpoint
New
is there any way to change the qwerty keypad into azerty? cuz i feel like azerty is much better
