Xperia Z5 - Wifi and bluetooth won't turn on
levircurtis
Visitor
The subject basically sums it up. I'm using an Xperia Z5 and my wifi and bluetooth will not even turn on. When I go to the drop down screen, nothing happens. When I go through settings, it shows wifi is turning on, but nothing happens.
27 REPLIES 27
CameronT
Champion
Hi @levircurtis,
Welcome to the community.
Do you experience the same issue in safe mode?
levircurtis
Visitor
Hey @CameronT,
I do have the same issue in safe mode.
CameronT
Champion
@levircurtis,
Try run a software repair but if that doesn't resolve the issue you will need to contact your local support team.
Debrup
Visitor
My brother and I both have got Xperia Z5 dual for our daily use. My brother is facing this issue in his phone where the Wi-Fi wont turn on and it keeps on turning on and doesn't find a wifi network. This issue has popped up around September. The interesting thing though is on restarting the phone the issue gets resolved. Along with this the phone gets auto restarted sometimes as well and on alternate restarts the Wi-Fi works. Another issue also cropped up where he was inable to receive an incoming call but that got resolved on its own a few days back on its own. I've never faced such an issue on my phone. Updating to Noughat hasn't solved it. Anything we could do about this?
Swaney
Visitor
Hi have the exact same issue.   I have a Sony E6633 (Dual Z5) I had tried repairing phone a few times - it makes no difference.
I have endeavoured to use Sony Support - but apparently my phone is a parallel import (I had no idea about this when I purchased) and Sony refuse to RMA on parallel imported phones.   The company I purchased phone from refuses to help as it is outside the 12 month warranty (by 2 weeks).    This leaves me with a pretty useless phone.
Any ideas on fixing? Or is it new phone time.
jacob_marsh
Visitor
i am experiencing the same issue, ive factory reset my phone twice in order to attempt to solve my issue, both times failed and im begining to get very annoyed as i do not wish to buy a new phone and yet it seems like the only solution. Expressionless_Face the issue seems to be software based but could also be hardware, im not sure to be honest. i just want to get it sorted. but one thing is sure, i will not be buying another sony phone in my lifetime.
NeoBeum
Enthusiast
Toggle Airplane Mode On and Off
jacob_marsh
Visitor
doesnt work/ sove the problem
Kabashka
Visitor
October, 2017. Phone restarted for no reason, and the same issue appeared. Wifi will keep "turning on". I cant use sony support cz they keep telling me to write here, write there, with not even listening to the issue.
