Xperia Z5 - Wifi and bluetooth won't turn on
levircurtis
Visitor
The subject basically sums it up. I'm using an Xperia Z5 and my wifi and bluetooth will not even turn on. When I go to the drop down screen, nothing happens. When I go through settings, it shows wifi is turning on, but nothing happens.
27 REPLIES 27
adamb2183
Visitor
October 2017 - My z5 has just restarted itself and now the wifi won't turn  on at all.  Tried all simple fixes to no avail.  Are Sony trying to phase this phone out or something? Lol.
Update - on again after about 10 restarts
Update - ITS HAPPENED AGAIN! 😞
LePierre
Visitor
I have the same issue, and this is how I solved it.
WiFi turns "on", but it does not see any networks.
Bluetooth won't turn on.
This is how I solved it.
1. Go to Settings -> About Phone -> Support.
Run the "Wi-Fi" test.
It takes a while, but it passes.
2. Run Bluetooth test.
3. Then reboot. My Wi-Fi now (often) starts as it should.
Please note that the problems comes back from time to time.
This is a work around, not a fix.
Sip3
Visitor
I have the same issue and this is not the only issue with the Xperia phones. This is my second z5 as they are bad!!! And on top f Sony being a bad phone they have the worst service ever!!! Stop making phones and robbing people!
profile.country.US.title
Qatrium
@Sip3
While I understand your frustration, but using vulgar words and curses won't help your case. Keep it clean, please.
Del3
Visitor
Tried your trick, it helped.
Interesting though, Wi-Fi doesn't hold the connection, it keeps loosing connection and then reconnects again ....
ssT123
Visitor
They suddenly stopped working WiFi and Bluetooth.. They solve a problem plz send me ........
Arhum
Visitor
Hi, i was also facing the same problem in my xperia z5 premium dual, i tried everything like reset,hard reset, software repair by sony pc software and flashtool to fix this problem but nothing works. When i become tired form every ways finally i fixed it by simple way.
Goto about phone in setting+ status + charging optimization. Make OFF your charging optimization. It will restart your phone. Now your wifi and Bluetooth both will work smooth .Enjoy
Nice-KilleR
Visitor
the Solution is in this tutorial guys  https://youtu.be/p_I7lrW9scw
dtgegtrhhrryh
Visitor
hey that doesn't work. any other solutions?
Supernando
Visitor
It worked on my Sony Xperia Z5.
Thanks so much!
