Hi.
After 6.0.1 update I can't answer call in most occurences. I swap green button, green/red buttons dissappears and phone still ringing. At this time I can't do anything. I only have to wait to stop ringing. Then I have missing call. When I call back, everything is ok.
How to fix it?
Thank you.
Hi @aas1,
I'm very sorry to hear that.
Are you able to recreate what you are experiencing with your device rebooted to safe mode?
Does this always happen while receiving calls from the same contacts or is it completely random? Have you experienced that specific part of the display not working properly lately? I'd recommend testing the display in Diagnostics, which is found under Settings > About phone > Diagnostics > Test > Display. Are you able to clear the entire surface?
that would usually clear some problems, so that was the right call to do, try to observe your phone for a few days to see if the problem comes back.
try to boot in to safe mode to see if the problem still persisted
software repair using Xperia Companion if it occurs on safe mode
What did the error read @Sari? Also, was the error message presented while installing Xperia Companion or while actually repairing the software?
Let me know some more details and I'll gladly assist you!
That sounds strange, but the SD card could be the cause.
Does the behaviour return if you insert the SD card again? If it does, can you try to see if the same occurs with a different SD card as well (I'm thinking your current SD card could be corrupted)?
