What would you like to know about Xperia Z1 Compact?
Johan
Master
Is there something you would like to know about the Xperia Z1 Compact?
Make a post if there is something that you would like for us to test.
And we will try to check this for you. :smileysmileythumbsup:
250 REPLIES 250
35thirlmere
Visitor
Is there any way to change the font or size of font in the message or e-mail app. I find the contrast between the fine lines and colour of the font against the background very difficult to use. I need more contrast between the two or a bolder font.
Any ideas?
cty85
Visitor
when is 14.3.A.0.761 releasing and what will be fixed?
SD card cannot write with 3rd party programs? (copy files directly with 3rd party file explorers)
notification sound stuttering?
camera autofocus crashing
battery drain/overheat bug
output sound plays from wrong speaker (base ring speaker correct vs ringing incorrectly from the earpiece speaker)
come on guys, just fix it and stop spoiling your flagship fone by not fixing and testing the phones thoroughly before releasing new firmware~ some of us don't mind waiting for stable and properly working firmwares rather than this nonsense~
rezwanrrr
Visitor
Any ideas?
@35thirlmere,
go to Settings > Display > Font size
then choose your option
hope this'll help you, waiting for your reply Slightly_smiling_Face
rezwanrrr
Visitor
can any one tell me.....where can I find the latest version [ number only ] of sony apps [ like walkman, album.........]
profile.country.RO.title
_alexdon_
invita1
Visitor
Why did Sony even bother to send it on the market with all these problems.
A lot off us is never going to bye a Sony product again after this experience.
Why not Finnish it first.
Written from my new Samsung which i bought instead of that piece.
rezwanrrr
Visitor
Thanks alexdon Slightly_smiling_Face
_alexdon_
Anytime.
alexdon
jna
Visitor
Hi,
My xperia z1 compact android 4.4 with kitkat update 757 is a great phone but
Once i have connected a usb key, the phone goes into usb host mode and everything works fine
After proper disconnection, the phone doesn't want to become anymore a usb slave (miss of freedom !) so when i connect it to my pc, absolutely nothing happen, not even charging.
Usb host mode still works fine, usb developper mode is still recognized by the pc but it is impossible to go back to the state before a usb host connection
It is a big problem because you cannot connect anymore your phone to a computer so, no photos or video transfer, no sd card backup.....
If anyome has a fix for that (except reinitializing the phone !).
00MIKE00
Visitor
Hi there, recently got a Sony Xperia Z1 Compact and have a few questions about it.
When I take a photo on the camera app, to view a photo it brings up the Google Photo app. How do I make it so that if I want to view a photo on the camera app, it brings up the album app?
Another question is is there anyway I can get rid of the moving as you scroll wallpaper to make it just one fixed image on each of the five slides?
Cheers
